1 - 12 of 12 Posts
I'd like to start a listing of repairs Victory Kingpin riders have experienced. Could be inside or outside the warranty period.
List the year, model, mileage, and repair issue. i.e.
2008 Kingpin - 1K - Rubber grommet on speedmeter/tach bracket
2008 Kingpin - 5K - Clutch cable broke
2008 Kingpin - 9K - Rectifier/Regulator bad, high voltage
Just "Quote" thread and continue listing.
Discussion Starter #2
2008 Kingpin - 6K - Chirping Belt - Tensioned
2007 Kingpin tour My ignorance 11,000 rear brake rotor. Vic brakes wear faster. Went to EBC approx $350 installed rear w/pads. note: Easy to change before problem.
Quote, copy and paste list and continue/add items:
2008 Kingpin - 5-6K - Chirping Belt - Tensioned (2 cycles)
2008 Kingpin - 9K - Rectifier/Regulator bad, high voltage'
2008 Kingpin - 10K - Oil Leak at Speed Sensor, Bad O-ring from Assy
2007 Kingpin - 11K - Rear Rotor Replacement
2012 Kingpin - 4k - Cruise Control Module fried - rode in rain storm
2012 Kingpin - 4k - Rear Pulley, bad pulley from day 1...belt always chirps
Both of the items on my '12 Pin are being replaced under warranty, bike in shop right now. They're even replacing belt under warranty because the pulley was warped causing belt to rub frequently.
2009 Kingpin - 10k left engine case gasket under warranty.
" " - 20k front brake pad replaced.
GUYS
the read break is to slow you down the Front break stops you.
If your pressing that hard on the rear break to warp it your not breaking correctly.
Put front break on first then the rear break
If you lock up the rear break you will go into a slid and wind up on the ground I guaranty it
1 - 12 of 12 Posts
