1 - 4 of 4 Posts
Never been a fan of the stock turn signal bar under the headlight on my 2011 XR. I have a set of Kurakyn LED bullet signals from my previous motorcycle. I would like to remove the stock front bar and signals (keep rear signals) and install the bullets in the upper corners of the forged bars. What I'm curious about is:
1. Has anyone done this?
2. Can I run bullets front and stock rear?
3. Anything I need to be on the lookout for.
Been searching but haven't come across any info.
My brother is thinking of doing the same thing. Sub'd. What do you have for a headlight bracket to replace the bar? If I come across any info. I'll let you know.
Wans't planning on using the signal bar again so removed the arms and reshaped it to use only the bracket portion. Rather than using the bullet lights as you can see in the picture I relocated the stock lights to the forged bar. This was first try at it. Might come up with a better idea for signals position.
I like that. I will have to show my bro these pics and see what he comes up with. Thanks!
1 - 4 of 4 Posts
