Combining 3” H3 lights with 2-¼” turn signals, the Constellation Driving Lights from Kuryakyn provide modern lighting technology with classic good looks all in a smaller package. Designed to mount directly to your forks with a set of the appropriate 2-piece clamps (also from Kuryakyn), the way forward will always be brightly lit.
These are not available on our website, call TJ at 866.931.6644 ext 817 to have a set of these sent to you today. You can also email him – send those to FORUM at RIDERSDISCOUNT dot COM with CONSTELLATION LIGHTS in the subject line and be sure to specify exactly what diameter two-piece clips you need.
Everything you get in the box.
Wiring is cleverly routed through the mounting plates for a clean look.
With the cast detents that go between the mounting “wing” and the light housings, it is possible to adjust precisely the angle at which these lights will project their beams.
H3 bulb for driving light and an amber-tinted lens for a turn signal.
