1 - 13 of 13 Posts
Looking for tires for a 2011 vegas 8 ball. Nice choice Polaris. I can find tires for bmw, Moto guzzi , or many other bikes with much better selection. End of rant.
what are you looking for?
there's lots of tires out there, depends what you want. you can usually vary sizing up or down one size according to rim width. your front tire is a tire for a certain look + like the big 250 rear sizes has its shortcomings. more traction is less wear and vice versa
Unless modified, every Vegas that ain't a Jackpot (back when they were called the Vegas Jackpot) should have a 180/55-18 rear tire. That is a wonky tire size and I only found 3 or 4 options. One of the popular fitments is a H-D Dunlop. I think Avon makes a tire in that size too. Front tire was a bit easier to find, but if you want matching rubber, yeah, your options are a bit limited. Might note they don't roll outta Spirit Lake with matching rubber, tho, since front is a Dunlop E3 and the fear is like a D417 or something.
Plenty options for the front. Not a lot of cheap options for the rear but Shinko, Bridgestone, Pirelli, plus Avon and Dunlop have a few different styles in that size. I will probably go with the stones. They have good reviews and great price.
Stock spec is a 90/90 x 21" Dunlop Elite... there are thousands of 90/90 size tire out there.
Ive got a perfectly brand new 005 Advance Shinko for your Vegas for a steal. Its a sport touring radial tire and a little bigger than the stock size will give you much more road handling ability. 120/70x21"
heres some info on it:
http://www.shinkotireusa.com/tire/005-advance
Discussion Starter · #7 ·
Finding tires to fit is not a problem. Finding tires that corner good and don't follow tar snakes ,that the front and back match is not easy. Ordered the front tire from dennis kirk . And picked up the rear tire from harly dealer before my original post. I'm hoping The wife will like them better then original tires. Front tire will be same as original.
Which tire did you go with? None of them will be great with tar snakes or cornering just too small of a tire. Most will probably be better than the stock Dunlop tho!!!
Too wide to fit on the rim from what I've been told.
vegas tire
I have a 2006 8 Ball, had very good service with Avon Cobra on the rear and RoadRider on the front. 8 - 12 k on the rear and over 13k on the front. Check out Bike Bandit, good prices and very fast delivery. Avon recommends 40 psi for the rear and 34 for the front. Check out my gallery for pic of front tire with over 13k miles.
1 - 13 of 13 Posts
