1 - 14 of 14 Posts
anyone running one of these w their pcv? thoughts?
Yeah I'm running the lcd200, love it. My only gripe is it could be a little brighter in the sun but if you change the screen colour to the yellow background it seems to work best in full sun...
What is a lcd200 guys?
It is a small screen , that when you are running the auto tune you are able to monitor you AFR's in real time at a glance , while riding your pride and joy .thumb up
OK thanks Mags- will look into them here.
I was talking to a guy about a month ago who had dialled his phone into his PowerComander on his Buell via an app. Forgot all about it until now. Does anyone have this?
Thanks lunatic...can you make in field adjustments with it for smoothing? I was researching the data logging...do you get a pretty good readout of rpms and such to make afr changes later? Im wondering if i could get rid of the stock speedo for this?
Lcd-200
I have been looking into this a little as well but thinking I would run a A/F gauge rather than the LCD screen. I assume you have WideBand 2 Commander hooked to your PCV? If so, the Wideband 2 also serves as an autotune so you should be able to datalog in that?
The regular autotune kit will not drive a gauge, you must have a wideband 2 commander to serve that purpose.
It says on the site wb/2 or at will work with the gauge. I have the auto tune and cant see why you would need a wb/2 when it only has one sensor?
The lcd200 works the same for the AT or the WB2, so no you do not need the WB2. I haven't had a chance to data log yet since I'm having issues with the 1 gb memory card. I have messed around with the infield adjustments as well and you can notice the instant changes on the gauge as you ride. I really need to get out more as I picked up the unit late last season and haven't got out much this year so far...
wb2
Ok, thanks for clarifying the LCD will work with autotune. I want the capability of running a gauge so I will go with the WB2. I wasnt sure about being able to see the LCD and mounting but it looks good on your photo.
Are you not able to monitor the A/F from one pipe bung and map both cyclinders with the same map? I figured this would get me very close then i could switch bungs and fine tune the other cylinder if neccesary. I didn't want to tack on another $100 for the additional sensor.
You can do it that way (switching cylinders) but to me that involves work, lol. With the AT you can read and compare all at once, I figured it cuts down on the mental notes you need to make between switching the lambda sensor over. I will try to get a video of the unit in action. Another thing I wish it did was when making infield adjustments you could split the cylinders up but it makes the adjustment to both (as far as I know, maybe I just haven't noticed where to separate them)...
Are you tuning for each gear with the same map? I didnt know if you see much difference in the gear maps. I thought I could lean out 5th at cruising rpm and tps
Yeah, no plans to tune per gear. I figure if your tuning a race bike then mapping each gear may be beneficial but for the street a map for each cylinder will suffice...
That would be great being able to do each cylinder w an infield adjustment. But with logging its feasible to go back in and adjust the af for that cylinder.
1 - 14 of 14 Posts
