1 - 3 of 3 Posts
Hey Vics, Where did you connect the power besides run the wire directly to the battery? I want to shut off the bike along with the LED lights. Do you have the link where to buy the lights? Thanks.
Run power to battery and use relay to turn on and off.
Or run power from battery to additional fuse box and power add on stuff from that. You might not have room to do that though.
If you are talking about decorative LED accent lighting, don't you want to be able to turn this on when the bike is shut off? Most of this type of lighting is used in situations where the owner wants to show off the lights when the bike is turned off and parked somewhere. Hence, you need a separate switch to turn this lighting on and off and the power has to be run to an unswitched power source like the battery or the input side of the starter solenoid.
1 - 3 of 3 Posts
