1 - 3 of 3 Posts
Hi all,
I installed a custom dynamics rear led bar and some knock off fork leds as well. As anticipated, i get rapid blinking on both sides front and back. I bought 2 load resistors and installed them in the front bucket. When the bike is off the left side blinks once and stops, the right side blinks slow like i want it. If i start the bike both sides just blink once and then stop and the turn signal indicator is blinking fast. Any thoughts? Should i move the resistors to under the seat (i thought it didnt matter)?
you need "one" resistor for each led. Where did you ground lights and resistor
Thanks for the reply. I thought you only needed one resistor per side since they share the same load. I wired the resistor to the same +/- wires that power the front lights. In any case i just ordered the load equalizer from custom dynamics for 30 bucks. By the time i buy 2 more of these crappy ones and have to wire 4 of them its just not worth the few dollar cost savings. I need to stop being such a cheap ass. Will report back in a few days once i install it.
1 - 3 of 3 Posts
