1 - 9 of 9 Posts
Hey just checking do you have to get the whole air box or will there air filter fit right in? thanks Rick
For an XC or XR only the filter is needed. There's really no "air box" on these bikes anyway, its built into the frame.
What you really should consider if adding a Lloydz AF is a fuel controller..
The fuel controller is a bit of overkill for just adding the filter. Disconnecting the O2 sensors will enrich the fuel mixture enough. He could even add the timing system without a fuel controller. Once bigger exhaust pipes are added, then he'll need a fuel controller.
I have witch doctor pipes on it I was told by previous owner and I have added the timing wheel set to +4 .
Then you'll definitely want a fuel controller if you add the AF
...we are so good at spending everyone's money here :devil
Yeah we are experts at it :)
1 - 9 of 9 Posts
