1 - 3 of 3 Posts
I have searched the web for the question I have and gotten nothing so here goes. I just installed the IAV on my 2013 vegas. On the end that goes into the IAC there are three O rings. All the pics I can find of the IAV either show two rings or none. My question is does the third I ring at the base go I to the IAC too? If so how do I get it in there. It doesn't seem possible to get it I'm there.
Did you lube up the O-rings with silicone or a light grease before trying to insert it , it should lock in with a click . Once installed do not try to remove it , you will destroy the O-rings ... Also , no O-rings should be visible once installed ...
1 - 3 of 3 Posts
