1 - 1 of 1 Posts
What we have here is a genetically altered motorcycle that used to be a 2012 Victory Cross Country. Given its 21-inch front wheel and saddlebag speakers, it can be seen as a transitionary mutation between the CC and the recently released Magnum. However, the characteristic we’re here to address can be found wrapped around the engine. (After all we’ve reviewed the 2015 Victory Magnum, in case you’re interested in the whole big front wheel and the kickin’ stereo thing.)
What’s that hanging on the side of the engine? Looks like horsepower to us.
When it came time to power this exploratory Cross Country, Victory’s Accessory Department turned to Lloydz Motor Workz, who astute readers may remember being mentioned in our 2014 International Motorcycle Shows Long Beach Wrap-Up Report – but we’re getting ahead of ourselves. The original plan called for a turbocharged Cross Country. Lloyd Greer, the Lloyd behind Lloydz Motor Workz, said he initially turned down the project because, while they make decent power, turbochargers are ugly and almost impossible to hide on a bike with no bodywork. After some thought, he called Victory back and suggested a supercharger instead.
Time Crunch
Like many projects, this one got off the ground and was already under the gun from the moment the Cross Country arrived at the shop. Although Greer was supposed to begin work in April, he didn’t receive the bike until June, leaving him with just 34 days to get the ProCharger grafted to the bike and running. Since it was destined to be revealed at the Victory Dealer Show, the kit should look nice, too. Other than the request for a satin finish on the components, Victory’s only stipulation was that the bike’s frame could not be altered – which makes sense in a whole bunch of ways.
The ProCharger filter housing and plenum are Harley Big Twin items. The intercooler is all Lloydz.
Because of the limited time, Greer ended up modifying the air cleaner housing and plenum ProCharger sells for Harley Big Twins. The intercooler was dropped next to the lower left side of the engine with the aftermarket coils mounted directly behind the intercooler.
Getting the ProCharger B1 Supercharger to fit was a challenge. Once the location formerly taken by the CC’s battery was selected, the supercharger’s outlet needed to be cut off and replaced with a 90° elbow. Space is so tight that the intake lives right behind the heat wrapped exhaust header. There’s not even enough room for a finger between the exhaust and the intake mouth. We have to guess that, at speed, so much air flows by the header that it won’t dramatically affect the intake air temperature.
The pulley system powering the supercharger is a work of art. Leaving the belt exposed on the top, allows the rider to see it turning when idling at a stoplight. The machined-from-billet aluminum plate that holds the assembly to the right side of the engine is too nice a part to be covered up by the floorboard and rear brake (not to mention the rider’s foot), but that’s the way it is.
That’s the belt powering the supercharger. It’s pretty cool to see it in action.
One of the nice things about superchargers, when compared to turbos, is that they don’t require the extensive exhaust modifications. Since the supercharger is mechanically connected to the engine and not powered by the flow of exhaust gasses, any old performance exhaust that can handle the volume of output will do. Being a Victory factory project bike, no one should be surprised that a Tri-Oval Stage 1 Exhaust out of the company’s accessory catalog graces the Cross Country.
Delivery Challenges
After spending more than 400 hours – almost 17 full days – actively working on the bike, Greer still needed to deliver the bike in the 34 allotted days. (Anyone who’s ever spent any time with builders knows that this kind of deadline time crunch is common.) So, he decided to put the Victory in the back of his Ford F250 diesel, which should’ve allowed him to make better time than with a trailer. Only, nobody told the truck.
This Cross Country spent the last year touring to Victory events to show the performance possibilities of the platform. It also appears to be a test bed for features that ended up on the Magnum.
Crossing the Ohio state line after the end of business hours for the day, the truck’s alternator decided to expire. This put Greer and his two driving companions in a bit of a pickle. If they stopped the engine, they were done until they could buy a new alternator. If the battery died – which it eventually would since it was being drained by running the engine’s electronics – they would be stranded. The solution to the problem was to stop at a truck stop, buy an extension cord, and wire the bike’s charging system to the truck’s. The extension cord ran through the cab’s split rear window, out the passenger window, under the hood, and to the battery. All non-essential electrical components on the bike and truck were disconnected, and the bike was started.
The supercharged Victory Cross Country idled in the truck bed for the 11 hours it took to drive from that truck stop in Ohio to Eau Claire, Wisconsin, where they finally found a Ford dealership that was open. To keep the bike’s engine cool all that time, they kept the truck windows open, allowing air to flow through the truck and out the split rear window where the bike was idling. With a new alternator installed, the Big Twin got to rest.
Although Greer only had 34 days to complete the supercharger project, the fit of the parts is remarkable. The plastic frame covers are trimmed precisely to fit the intercooler.
Thanks to their creative thinking, the Cross Country made it to Victory’s Wyoming, Minnesota production facility in time to be packed on a truck and shipped with the rest of the bikes needed for the Victory Dealer’s Show in Las Vegas. After that event, with the exception of some time spent back at Lloydz Motor Workz for some fine-tuning, the bike has been displayed to the public at various rallies and shows – which is where MO discovered the bike and arranged to get our grubby mitts on it.
Life in the Real World
This supercharged Cross-Country is remarkably cold-blooded, refusing to start without a slight twist of the throttle. The additional load on the starter motor can be heard when attempting to crank the engine over for the first time with the compression strokes slowing down the turnover dramatically. When the engine fires, though, the additional mechanical processes are immediately apparent. The sound of the belt on the pulleys mixes with the mechanical noise of the ProCharger and the intake sucking sound playing in the background. Roll on the throttle, and the music picks up its tempo with the hearty bass note from the Victory Tri-Oval Stage 1 Exhaust announcing its presence.
The engine compartment looks remarkably stock from the right side – unless you look behind the rider’s foot. A twist of the throttle puts any doubts to rest.
What you’ll also notice is how incredibly rich the bike runs at idle. While the engine delivers a nice, lumpy cadence at idle – once it’s warm – the mixture remains rich enough to notice with the nose. Get a little carried away, rapping on the throttle while waiting at a stoplight, and your eyes may burn from the hydrocarbons. Greer says the richness at idle is intentional. A rich intake mixture cools the combustion chamber, reducing detonation and helping preserve engine durability.
Then the light turns green, and you pull away expecting a beast. Instead, you get some pretty benign acceleration. This is the crux of this supercharged engine: Ride it like a stock bike, and it’ll feel unexpectedly tame. While the bottom-end torque feels like a well-endowed V-Twin – stouter than its 106 cubic inches – you have to give big doses of throttle while spinning up to the rev limit before you really experience the acceleration this supercharged engine can mete out. To deliver the maximum benefit of all that top-end power, Greer raised the rev-limit to 6400 rpm!
Smokey Burnout Editor, Troy Siahaan, summed the experience up best with: “For someone used to high-horsepower sportbikes, the supercharged Victory was initially underwhelming. However, I learned that the beauty of the forced induction occurs the higher in the revs you reach. Big Twins are known for their torque, but fall flat quickly once they start to spin faster and faster. With the supercharger, you retain the bottom-end torque, but also get the top-end rush to boot. It’s the best of both worlds!”
A Victory Tri-Oval Stage 1 Exhaust gives the engine its bark.
“Unlike the boost from a turbo, which delivers a robust hit only after pressure ramps up, the supercharged setup by Lloydz simply delivers more power everywhere, almost as if a third cylinder had somehow been bolted on. While the power curve hasn’t been radically altered, the extra grunt on tap dramatically shortens the time between gearshifts – I can’t recall hitting a Victory’s rev limiter until I rode this one,” agreed International Racetrack Editor, Kevin Duke.
Or, as I exclaimed to Troy at a stop sign before blasting away en-route to our photo shoot location: “This bike is a blast when you ride it like a complete dickhead!”
Read More Here:Lloydz Motor Workz Supercharged Victory Cross Country Review
1 - 1 of 1 Posts
