1 - 6 of 6 Posts
Can someone post a picture or some insight as to how these bushings go on ? The kit has 12 bushings , do I use them all or only 8 ? Can someone explain or put up a picture that knows for sure how they go , here are mine , pretty sure they are wrong .
Any insight greatly appreciated !
Mags, not sure what pieces come in the kit as mine were already installed at purchase. Looks like you only need 8 though. You should have 4 bushings with a shoulder on them, and 4 more short ones. The short ones will install against the fender, then the shoulder type bushings rest against them, shoulder inboard. At that point, reinstall the bag mounts. This is my best guess at looking at my I stall without actually taking it all apart.
Will have pics posted shortly!
OK , so , basically I need to rotate my outer bushings 180 degrees it looks ... Thanks Brother !
That was an easy one! Glad to help!
cheers cheers
you can either use the 4 split bushings or pull the fender struts off and use the 8 solid bushings, I'm lazy and only have the 4 split bushings on for now.
1 - 6 of 6 Posts
