Auto floor mats, truck mud flaps, worn out bicycle tire, cheap rubber floor/door mat, old rubber boot sole, ,,,,,,,,
If that's from my former Big Red Machine, the pedal was ...Below is a picture of the aftermarket brake pedal on my 2012 XCT. As you can see, three of the four rubber pads on this brake pedal have come loose while riding and are long gone - exposing the slots into which the three pads were glued. Does anyone have any suggestions for where I could find some replacement rubber for these slots? I would be happy to cut, carve, shape, etc. the rubber but am just not sure where I could find some. It is about 1/4 to 3/8" thick. View attachment 260264
the 3m tape you received is likely counterfeit. Particularly if the product it was on was made in an Asian country.The rubber pads at the link above worked GREAT! They come with what appears to be a 3M adhesive double sided tape applied to the back. I was unimpressed with this tape. I easily rubbed it off with a finger. I scarred up the back side of the rubber pads, scarred up the metal surface to which the pads would be applied with a small cut-off wheel in a Dremel and glued the pads in place using E6000 glue. They seem to adhere well but time will tell. The fit seemed very good. each pad fit into its slot perfectly and tightly.
