1 - 20 of 35 Posts
Hey Fella's, I'm new to the forum. I just bought a 05 8 ball, one of the first things I plan on doing when I arrive home is lowering the bike (I'm currently deployed). So basically what I'm looking for are pics of lowered 8 Balls, maybe a couple of before and after pics. I'm just going for a 1.5 to 2 inch drop.(I have used the search engine).
First off,thanks for serving!!cheers Here's a pic of mine lowered,sorry its a cell phone pic,and there aren't any b4 pics,but here ya go.
Nice...how much of a drop did you go with?
I think it's 1.5. Make sure you move,and secure the wiring harness when you lower it.
Yeah I was reading about that, while trying to find a good DIY post somewhere. Is there a DIY on the lowering of the bike?
As far as lowering it,it apears to be pretty straight forward.It's a matter of replacing the dog bones. As far as moving and securing the wiring harness,the back wheel will have to come off.
I am not sure what kind of riding you do. I own a 05 8 ball and i wish i could raise it sometimes. I scrape pegs and frame all the time. I come from a sport bike back ground so i guess i haven't give up the life yet. If you want to go to bike night and look cool that is fine. Just think about that once you do that you can't got carving the corners. i think that bike looks great in stock height. I handles like a dream. I just can't see how lowering it would do anything but give you headaches.
Semper Fi
02-07
Been riding 11 yrs, nothing but gsxr's. This is just a simple like you said bike nite bike and bar hopper.
Go with an air ride suspension so you can have the best of both worlds. You can lower it when you want, but you can raise it back up to actually be able to ride it through corners properly.
There are a LOT of picture threads (in each subforum), be sure to check them out. Look for Diamondrmp and his bike, he has an air ride and it looks damn good.
I agree, very nice bike. I really don't wanna drop a grand on suspension right now though. I already bought apes and exhaust, there getting installed as we speak. Ill post some pics when I get home, in about 73 days!!
Found these instructions on victoryonly.com, I'm considering the 3inch drop now.
3 INCH AND 1.0INCH LOWERING LINK FOR VICTORY MOTORCYCLES INSTALL INTRUCTIONS
Installation of any suspension components other than factory OEM may cause riding characteristics
of the motorcycle to change. It is the rider’s responsibility to operate the motorcycle safely
STEP 1) All motorcycle accessories parts and or accessories are strictly for off road use or off highway use only.
All motorcycle accessories and or a trained victory motorcycle mechanic must install parts.
The person installing all parts and or accessories assumes all liability for that part.
STEP 2) Remove the tomahawk lower links from packaging and inspect prior to installation.
Make sure you received 4 thrust washers.
The 4 thrust washers are your install hardware kit.
STEP 3) You must raise the rear end of your motorcycle (use a motorcycle jack or factory specified lifting device and lift in the correct location)
and get the rear suspension to the neutral.
Once you have the rear suspension in the neutral position you can remove the 2 fasteners securing the factory suspension links.
STEP 4) Once you have removed both factory suspension links inspect all suspension components for wear.
Consult factory specifications for acceptable wear and replace all necessary parts.
STEP 5) Now install your new tomahawk lowering links. The larger wider end of the lowering links must go towards the rear tire.
The smaller less wide end is towards the front or the motor side. It may be necessary to adjust the height of the motorcycle using the
lifting device to help align the bores of the lowering links. Once you have installed the lowering links onto the suspension bearing you will need to install the
4 thrust washers.
You must put 1 thrust washer in each of the lowering links bores, and then install the factory fasteners you removed earlier.
It is recommended that you use thread locker and the correct torque specifications for all fasteners when installing.
Lowered the bike yesterday
before:
after:
Rebel! Looks great. thumb up
Hope you pulled your fender and rewroted your wires before the tire eats them.
Bike looks good thanks for your service
That looks awesome,nice job!!thumb up
Discussion Starter #16
Thanks guys! Yeah I pulled it to the side and zip tied it to the frame, how ever I didn't grind down the piece on belt housing, no belt chirp.
just currious, did you have to remove the rear tire completely to address the wiring issue? I have some 2" drop links to install sometime soon.
thanks in advance.
j.
2007 Vegas 8-ball
Discussion Starter #18
nope just seat and rear fender, it was cake!
Discussion Starter #20
1 - 20 of 35 Posts
