1 - 6 of 6 Posts
If I was looking to build a maxxed out N/A powerplant (116) would the Tri-Ovals stand up to what I want?
Would they be optimum, or would you recommend a different exhaust?
Your best bet would be to ask who's building your more they know what exhaust would work best
prolly not
first issue are the kats in the head pipes, second is its very restrictive as the exhaust must go around a solid end thru the louvers in the big long baffle. my guess is the RPW thor or newest bassani mid length road rage. i have the tri-pro installed by the former owner but drilled out for better sound + performance. its quite heavy as well! i am thinking about either pipe i mentioned above
so far from whats been said about the stock headpipes with the cats is they are the best performers up to 130 hp
Define maxxed out? Do you mean every currently available bolt on part along with a custom tune? Or are you going to have a proper engine builder pull it apart and BUILD the motor?
If A, there will be a difference between exhausts but it probably won't be massive.
If B, find a proper engine builder that can also build a custom exhaust tuned to the build and forget about anything off the shelf.
1 - 6 of 6 Posts
