1 - 6 of 6 Posts
Anyone done their own install of the mbw front turn signals? I was reading the instructions and it says you have to separate the forks enough to let the unit slide over it and re assemble.
How tricky is that process?
Thanks.
Jack bike up slid tubes down.
remember power and ground are different on the right front blinker
next time you ask a question say what year and model your asking about
I did this job , do not rotate tubes to work them down !!! You WILL leave permanent scratches in the tubes and they will look like **** ! I cut 4 small wedges out of a 2x4 and gently tapped them into the spaces in the tree separating them just enough so the tubes would easily drop down , go just far enough so the led's slide over the top of the tubes . After this , its simplicity . As VJ said you must lift the bike off the ground . Good luck , and have a buddy there for an extra set of hands , this will help immensely .
Mobs , do it like I did ... You will not scratch them . Took me 5 min. to fab up a couple wedges ...
1 - 6 of 6 Posts
