1 - 20 of 24 Posts
Has anyone found a solution for the 2008 Vision's mirror location? Mine give me a great view of my knuckles. I was thinking of sticking some of those ugly round little convex mirrors in the top corners of each mirror to overcome this shortcoming. Unless it is not legal, I would think that a double faced mirror would have been a great idea.
It is slightly frustrating not seeing behind me.
this is my work around, best of both worlds ...stylish and practical
the mirrors look smal, but once you get the right angle, it's all gravy :)
cheers
What did you mount to? As far as I can tell my Vision doesn't have mirror posts. Most accessory web site exclude the vision when revealing which bikes the mirrors fit
got these mirrors from Arlen Ness, I believe the vision has a spot where you screw the 'bolt' adapter and then the mirrors...
Another alternative is the blind spot mirrors. People mount the directly above the existing Vision mirrors. I notice the mirrors didn't do much good when I test rode a Vision a while back too. Some people are the right height or something because they have no issues with it. I dunno.
http://www.autosportcatalog.com/index.cfm?fa=p&pid=3445&isc=612
No mounting available
Unfortunatly, on my VISION, the brake master cylinder and Clutch lever housing don't have mirror mounting holes.
Thanks Lova been thinking of doing the same thing On my vision 8 ball 2011. Hate not seeing behind me. Got to see if that car or truck is going to stop or what.
lova
Saw another biker that put mirrors like yours and in the old mirror location he put in more speakers. Cool if you want the sound cranked up.
Once you get used to the mirrors they work fairly well. At first I couldn't stand them, now I have no problem seeing whats behind me.
I got the vision 8 ball and mounted a mirror on the right side and a GPS on the left. Mirror works great I can see behind me.
I've never had a problem. I did adjust them by pushing in the center to where they worked. But as on all my vehicules,I've added two spot mirrors in the outer top corner. I've done this for years as I tow 5th wheel trailers and this helps a great deal.It does take a little time to get used too.
my one complaint
is the mirror placement. All I see are my knuckles too. A bit disconcerting as I have to duck and weave to see behind me which, in some cases might be too late. May have to do the extra mirror on the clutch/brake reservoir.
Aftermarket mirrors.
You can get the old fashioned mirrors that clamp to the handle bars like they us to in the old days. Probably find them in J&P Cycles, Dennis Kirk and others. Also some of the custom bike makers probably offer them.
Might work if there were no passenger or trunk in the way.
Adjust your mirrors and ignore the 1/3 of the mirror that shows you your knuckles. The rest gives you a nice view behind you and the lane next to you. It is a lot like your car mirrors where 1/3 gives you a nice view of the side/back of the car.
I push the mirrors nearly all the way out to reduce blind spots. This is uncomfortable at first, but once you realize that your blind spots are almost non-existent, it gets easier to use. The position of the mirrors forces me to move my head a little more (I don't get complacent, which could be deadly) so that I see everything beside and behind me, including the positions that are traditionally blind spots (4-7 o'clock or so). This is an article that explains the theory. Yes, it is specifically about car mirrors, but the theory works on bike, too.
I think the mirrors are designed so you can see when changing lanes.
I have mine pushed all the way in on the most outer point. Kinda set up for blind spots.
As far as what right be hind me I move my head a very little bit to see whats behind me
1 - 20 of 24 Posts
