1 - 4 of 4 Posts
I have a 2011 crosroads every so often especially after some highway running ,When I gert off the ramp the bike will just shut off,,It will start right back up no problem and run fine,,,Has anyone else had this issue?and what WAS done to fix it? thanks
I've had that happen a couple of times since I bought my bike in April. I assumed that it was a side effect of my intake/exhaust setup. I have not had it looked at yet but assume it has something to do with the bike running lean.
If the bike is still under warranty get it looked at by the dealer. This sounds unusual.
There is whats called a Idle Air Valve or IAV it is suppose to keep your bike idling. You could have a vacuum line not all the way on.
See dealer and give him all the information you can on how it dies on you.
Most people don't give all or good information so it makes it hard for a dealer to fix and your only screwing your self by holding back.
1 - 4 of 4 Posts
