1 - 8 of 8 Posts
cheers , I have a 2001 sc and I thinking about a motor swap . will a freedom 110 ci 6 speed work , or do I have use a freedom 5 speed 110 ci motor being a better choice .
thanks ,
g.:crzy:
no 110 6 speed will not fit.
I don't believe the 110 5 speed will fit either
If your looking for a motor Rylan at "The Vic Shop" has a motor for sale
Thought youd flooded it for a second there.
NO its to big for your frame.
Send your motor to the Vic Shop and for a few thousand he can make it faster then a 106
Are the earlier freedom 92's that much of a difference? I know I've seen them in the early vics. Rylan would be the guy that knows give the vic shop a call. He probably has an engine for you.
The only swap engines that fit our frames are Freedom 92 engines from 2002-2005 I think? 1999-2001 engines are "Hammer" 92C 1st generation engines.
1 - 8 of 8 Posts
