1 - 9 of 9 Posts
Had my vegas on the dyno monday. Well happy the way it runs now :cool: My Thor exhaust muffler its blued up, headers are ok. Dyno tech told me the downloaded map i had was seriously lean mid-range.
Anybody else had the same with a 2-1 pipe
Most aftermarket pipes will blue, theres different cleaners that will take care of it, but it will blue again.
Sent from Motorcycle.com App
We all run cheap shitty gas cause thats all we can get. Bluing comes from the heat of the exhaust. Bluing will come back no matter what you do.
I know my Thors the muffler didn't slip on all the way. Maybe it would be sucking fresh air into the muffler leaning out the flow? Just a thought.
head pipes always blue cant say i have seen a muffler turn blue that far back.Seen a muffler turn gold but that was from guy putting a 2 into one on harley and not rejetting carb was running way to lean
Muffler on the Thor is a poor fit, i sealed it with exhaust silicone.
Dyno center has air cooling the bike like 100mph wind while on the dyno. The downloaded base map i had on was seriously lean Tech told me :confused: He said it could be due to poor chroming and to get in touch with manufacturer. Powercommander Dyno shop has a good reputation. Prob get it rechromed :mad:
Poor chroming is BS
pull mufflers and with a hacksaw add extra cross hatch cuts put mufflers back on and that should fix any leaks you might have,
Poor chroming is BS
Hi, made sure seal was good and used exhaust sealant as well.
You never know if it might have made a leak on the dyno when he had her on full chat!!
Will have a look again this weekend thumb up
1 - 9 of 9 Posts
