1 - 4 of 4 Posts
Lloyds torque tubes, K&N filters, PCV, Dyno set up, Bassanni turn outs, Lloydz timing wheel, MSD ignition, WYRD XV40 cams, underdrive pulley, 5½ rear rim, running a 180, 150 up front, Penske shock, plus loads of little bits.
110hp 124ft/lbs
Unfortunately not running well at the moment, see seperate post in the help forum.
I like the White Walls and the pipes.
Bet you don't see many over there in the UK.
Speaking of, if you feel like it, you can put your location in under "User CP" then "Edit your Details". It makes things quicker when location can be a factor. A lot of people put the year and model of their Victory in their signature; also accessible under "User CP" then "Edit Signature".
Nice .... Hope you can find the glitch ....
Andre using TaPaTaLk
1 - 4 of 4 Posts
