1 - 13 of 13 Posts
Here we go playing 20 Questions again with no specifics. Front end of WHAT?? Tank? Fairing? Fender? Sheesh!
Oil drain plug washer, Blaaaaaaa
Sorry OP, couldn't resist, how about the front fender and brake calipers, check if the bolts are still there or tight... Also on your speedo & RPM & brake line brackets have some washers
Most times it is the easy stuff..
Andre using TaPaTaLk
I just removed the body work on front end. Come from around above fuel tanks. Didn't have blinkers or headlight out
What piece did you remove when they fell out?
there a hard plastic washer white in color. I went through everything again this morning with no luck. all diagrams didn't show anything so its 3 washers light now haha
Did they show any markings that would indicate they had been part of an assembly? If not, they are "extras."
I have had my vision apart many times. I have even look at Vic's parts finch and have never seen or come across them. When the vision first came out they said the washers go on the bar I circled. But when I ask dealer they never could come up with p/n or where. So don't worry if you can't find a place for them
1 - 13 of 13 Posts
