1 - 14 of 14 Posts
My bike has been at dealer for several months now with no solutions..started out with a pre spring clean up and routine oil change,found a fuel fitting at top of pump leaking removed pump tightened fitting replaced filter while in there put back together would not start re checked everything same result checked to see if bike was getting fire and it was not..sent it to the shop all relays fuses and TPS and CPS checked good replaced computer still nothing am waiting on new chip for computer..,all grounds checked good.,, any other suggestions would be greatly appreciated
You forgot to post the model and year of your bike:confused:
never heard of a dealer putting in a chip.
I don't think your telling us all or your leaving info out.
Is there spark
are you sure the pump is putting out 50psi.
Are the spark plugs wet or dry. If there dry your not getting fuel.
Its a 1999 V92C... Yes fuel pump working properly.... No spark... Bike was running literally minutes prior to finding fuel leak..all the above mentioned componets check out fine with ohm meter except computer(ECU) it was slightly liwer on ohms than svc manual stated so it has been replaced chip from stock ECU was put in and still no spark..new chip ordered waiting for it to arrive
ECM's rarely fail and they aren't an inexpensive part as I'm sure your finding out. Sounds like your guy has the service manual so there's not a lot I can add other than stupid obvious things like making sure the kill switch is functioning & in the run position (don't laugh I've seen it before) I would suspect the coil/connection could be the culprit. Most of my 99's issues have been failed sensors & not all showed an error code. I did replace the metal cased ECM with a newer model plastic cased one that seems to have eliminated a heat induced stalling issue I was experiencing. I've also had weird things like the speedo going goofy that were solved by disconnecting the battery for a while & everything comes back up working correctly. These bikes have a lot of personality :)
Shop has my svc manual coils checked good as well ground strap removed cleaned and replaced plug wires replaced... Getting fire from stator but between there and plugs spark is lost.. The only thing that did not check out according to svc manual was ECM. So i bought a new one $799 shop put it on and took chip from stock ECM and put it in new one.. Still no fire...so i ordered the new chip $115 however no one has been able to confirm if this chip that supposedly controls air fuel mixture and blah blah blah will prevent igniition from firing... Only a "well maybe" if air and fuel aint right the ECM may keep it from firing as a protection mechanism
Thank you.. I will give it a shot
You may have already said but did you check the resistance/continuity of the plug wire(s)? If no spark is getting from the stator to the plug it "could" be a wire issue especially if they've never been changed......Maybe the expert can help also. I'll keep looking around.
Good luck
2011 thread
The guy in this thread had a similar issue......Victory Forums - Victory Motorcycle Forum > Victory Motorcycles > Victory Tech and Performance Section '99 V92c Won't fire — Please help.:confused:
I've seen his issue in other vehicles before....
Cheers
Good luck
The stator is the charging system has nothing to do with the spark.
Machs Nichts
Copy all and it's machs nichts. IF he's not getting sparks a place to look is the spark cable or the plug itself...new or otherwise. Even more important is it's "VERY" unlikely a "charging system" issue....look for a simple problem because it is most likely.
tried new spark plugs?
my GSXR750 refused to start the other day, after running the previous and just got the whole shebang going after it sat for 5 years.
New set of plugs she fired straight up!:)
1 - 14 of 14 Posts
