1 - 5 of 5 Posts
I'm installing a Denali pwr distribution hub in my front fairing, I need to find a switched pwr source to connect to the relay in the hub? Anyone have any ideals? Thanks in advance.
There's a power distribution relay wiring diagram I did somewhere here.
I tapped into one of the wires coming off the ignition switch for that relay. This can also be used for your needs. I think it is the brown wire on the ign switch.
Since you're only using it to trip the relay, then pretty much any wire that is hot when ign is on should work.
Ok, I just tapped off my low beam light I may look for another source later on.
Thanks everyone.
I tapped into my high beam for my LED driving lights; they were wired hot and I kept leaving them on killing the battery. It's set up on a relay so there's very little power craw through the tap. I will never leave them on by accident again :D
1 - 5 of 5 Posts
