1 - 11 of 11 Posts
Look up Bbob forum member and download the manual for your bike ... I change my plugs every year
TaPaTaLk for VIC forum
Well when it is within both numbers then it must be " OK " right ??
Didn't know the manual stated imperial sizes too ?
Yup Imperial & Metric
I thought the recommended gap was .040? Which mine are set at and its running better than ever. (considering when I changed the plugs I also changed the wires, cleaned AF, removed the cats and added DK Thunder Torques)
Maybe different models different gaps ??
Can you look in your manual pAiN ?? Just for fun ??
The manual for a 2013 XC says the following about type and gap of sparkplugs in the maintenance section: NGK DCPR6E / .8 mm (.032"). This is in the "Service Specifications" section, "Tune up" table, top of page 2.2.
G'day,
Vinish
So that is the same as Jackpot & Hammer manual
Thanks Vinish
From the 2014 Cross Country Tour Owners Manual:
Spark Plug Type: NGK DCPR6E
Spark Plug Gap: .031-.035 inch (0.8-0.9 mm)
Spark Plug Torque: 10.8-14.5 ft-lbs (14.6-19.7 Nm)
Inspect every 5,000 miles (8,000 kms) and replace at 30,000 miles (48,000 kms)
2008 vision is
NGK DCPR6E
Gap .036" or 9mm
Torque 8.5ft lb or 11nm
Apply anti-size compound sparingly to threads
1 - 11 of 11 Posts
