1 - 5 of 5 Posts
Had planned on buying the pipe for my '09 Vegas last year when some work related issues came up and delayed my purchase. Now every site I go to says "discontinued". That sucks ! :mad: Really liked the look of them over the RPW slash pipes.... they had a longer swoop that covered the swing arm and had heat shields around the entire pipe.
Anyone know if there is a "replacement" pipe from Ness or what is up with this ??
I had the Victory Swept pipes. Are these the ones you're asking about? Because the Ness were called slashness and were a little shorter.
From what my parts guy said, the swept is discontinued and the x-bow replaced it. Not sure about the Ness pipes though, if the Ness swept is the same as the Victory swept.
Ness swept is the RPW slash. It is the short one. The Vic swept(the longer set) should be easy to find. They are slugs as far as power goes and most guys switch them out for a better pipe.If that is truly the pipe you want, just post a wanted ad on a couple of the Vic forums.Should be able to find them pretty cheap. Ive seen 'em go for a couple hundred bucks.
Actually, Ness came out with a superior swept pipe called the "signature series". looked similar to the factory swept, but actually made power unlike the stock. The RPW swept is shorter, (apparently louder) and doesn't look nearly as nice as the signature series...... did. Must have been some issue with them though....... found several websites that still advertise them with a disclaimer saying they have been discontinued.
1 - 5 of 5 Posts
