1 - 3 of 3 Posts
2005 Kingpin. Original neutral safety switch went out. Ordered a new OEM replacement. Everything back to normal for about two weeks and the new one went out. Anyone ever have an issue like this and what was your fix?
You may want to remove the switch and check it with a meter to verify that the switch actually failed. It might be the wire or connector that actually has the problem.
I will have to test the switch however it starts right up when I ground the wire to a bolt but not when I attach it back to the switch. That's why I'm thinking it might be something damaging the switch.
1 - 3 of 3 Posts
