1 - 20 of 193 Posts
Discussion Starter · #1 · (Edited)
Hey guys,
I am the owner of a new 2013 8 Ball, I bought it brand new last month from Hernleys in Elizabethtown PA. Ive been riding since I was 12, ( Ill be 24 soon). Raced motorcross, track days all over the east coast on sportbikes, you name it Ive probably been there, so I consider myself an experienced rider, as well as a Mechanic as that is my profession.
Id just like to get that out there so nobody thinks im new to this.
Anyway,
Within the first 50 miles of a brandnew bike, it shut off on me 4 or 5 times. All of them happen as soon as I pulled in the clutch to downshift. Just shut right off. I took the bike back to the dealer, waited around an hour and was told they found a loose nut on one of the circuits and hopefully it was fixed.
Around a week after that, it has shut off on me several more times, not even 150 miles on the bike yet. Again, each time it happened it was as soon as I pulled the clutch in to down shift. Back to Hernleys.
I took the bike back monday sept 30th. It took over 9 days to get my bike back, as I picked it up October 9th. They told me twice they didnt get a chance to get around to looking at it, and then we had to wait for a part.
I was told they replace the Idle Air Control valve and that, Duane, the owner wanted to talk to me. So we talked, and what he told me was this.
That they went ahead and replaced that part, but it was likely my fault the bike was stalling because;
I AM NOT SUPPOSED TO REV THE BIKE, AT ALL, AS IT CONFUSES THE FUEL INJECTION. DONT REV IT WHEN YOUR SITTING STILL, AND DONT REV IT TO DOWN SHIFT, JUST PULL IN THE CLUTCH AND SHIFT.
Seriously?! I cant rev my bike to down shift??? He said it as if it was a normal thing and no big deal.
Anyway I took the bike home, 15 miles later it has shut off twice, and it is now back firing a good bit, random pops, poor bottom end, as well as throttle responce.
Oddly yesterday while riding I ran into another Vic owner. Bought his bike from the same place, was having similar issues, and got the same story, DONT REV THE BIKE. I thought this was weird.
So today I called two other semi local dealers.
The first I called was not suprised to hear from me, in fact he seemed to know my story before I told it, and said they fixed 8 or 9 bikes, all that were bought from Hernleys within the past few months due to bad service and a rude owner.
He was familiar with my issue and told me that they had seen several fuel injector issues, poor seating of the injector, or bad orings on them, so this may be part of my issue, but he said there is no reason at all why I should not be able to rev the engine for down shifts, as we all know thats what you do with any manual gear box.
Also while my bike was at Hernleys the 2nd time it got a nice scratch on the side cover, probably from someones boot as they went to get off the bike. The owner "buffed it out", well guess what, the scratch is still there and he could care less.
So thats my story.
A brand new bike that runs like crap, serveral people from the same dealer with similiar problems and no help from the origial dealer, and im being told, NOT TO REV THE ENGINE, like its a normal thing for these bikes.
Sorry for the long read, but has anyone had these issues or is aware of a fuel injection issue, electronics problem etc etc? This is a real low blow for me as I have a brand new bike that seems to be getting worse and worse with each mile.
Thanks,
Shane
Shane,
It's well documented on all the Victory forums that Victorys don't react well to throttle blipping. The problem, as explained by KevinX (respected Victory wrench), is that when the throttle is blipped the computer senses this as a throttle overrun and shuts the bike down. With practice you will learn how to get away with blipping without having to worry about shutdown but since blipping does nothing but waste fuel it may be easier to just break the habit.
I call bullshit... I blip my throttle all the time. (Ex motocross/Arenacross rider as well). My bike has never died while blipping to downshift. KevinX is a reputable guy on this forum and I believe there is some truth to what he says. That being said this sounds like a more extreme issue. Disconnect your O2 sensors and see if that makes a difference. Since I installed pipes and PCV my 13 Highball blipping is causing some more popping. That could also be cause I am in love with my exhaust sound though and am a blipping fool. Who cares about how much fuel one uses on a motorcycle? Ride for 2 hrs buy more fuel... Just saying.
Can i ask why a person would blip the throttle on downshift anyway? Not something i have ever done, but yes i heard vics dont like it.
Sent from Motorcycle.com App
Well if your riding hard and there is a corner coming up or have to make a quick stop blipping is necessary. If you don't blip you run the risk of a compression slide and loss of control. Talk to any racer and they will give you the same answer. Or just watch a superbike / supercross / motocross / supermotard race.
Discussion Starter · #9 ·
Even if I dont blip the throttle, Im still having my other issues as described, popping/back fires, throttle responces, no bottom end...
It would seem the part that Half_Crazy posted a link to describes all those problems I have, so I may have to give that a try.
But explain this to me,
Almost everyother bike make today, weather it be a road or dirtbike, is fuel injected.
Why can I rev the piss out of a fuel injected, $6000.00 Dirtbike, and not have it miss a single beat, but if I even "blip" the throttle of my $14,000 to $20,000 Victory it seems to want to have a hissy fit.
I thought these were supposed to be a big deal, cutting edge,the bees knees, whatever you want to call it, but yet we cant figure out coming up on 40 year old fuel injection technology?
I'm a blipper (rev matcher), a trick alot of sport riders use to keep the suspension settled for mid corner downshifting, you don't get that front end dive like you do if you just downshift. It's just habit for alot of guys, me included. I have found on Vics though at slower speeds like rolling up to a stop sign it doesn't like to be blipped and somewhat pukes on itself, I just figured it had to do with cylinder size and the fact that the IAC acts like a big vaccum leak when off the throttle...
Discussion Starter · #11 ·
Not only that, its also extremely dangerous that my bike, or anyone elses for that matter, shuts off when you least expect it, especially if your moving.
What if it shuts off on me and I get plowed by a truck because I couldnt get it started and out of the way.
Is that my fault that Victory, and my dealer, knowingly put me back on the road with a bike with issues?
I for one am not arguing with you, I just had the arguement the other day with Victory1 from this site. He said this is not a common problem, hmm. I just have seen many people get upset over the blipping and ive never understood the why of it. I dont do it, but i can without it dying. You must have to many "hodge podge mods" done to it and have witchdoctor parts on it!
Sorry to hear of your troubles, I think the bike needs to go back and you should get a different bike altogether. I thought there was a 30 day or something satisfaction deal?
I gotta say I call BS on this too, I blip like a mad man because I love the sound of my Witch Doctor muscle car mufflers and I have never has my XC cut out on me. Just my .02 but I'd be seeing an attorney and filing a lemon law claim if that's available to you in your state.
Discussion Starter · #14 ·
There are no mods done to my bike, 100 percent stock.
I know your not arguing, justs stating why I do it. I cant not do it, just a habbit ive done for years.
Talking cars, Heal-toe down shifting, (same thing as blipping the throttle), is the only proper way to performance driving. Hard to learn, but when you master it, its an art, and youll never go back.
Discussion Starter · #16 ·
Also, an important thing to note.
Prior to buying my bike, I did the Victory Demo Ride with all the new 2014 models, I rode a highball, 8 ball, and a judge I think it was.
Rode them all for about 20 minutes a piece, rode them the way I want to ride, (didnt beat them, but I wanted to see what they can do) and blipped the throttle every single downshift, and there wasnt any issues, no stalls, popping, nothing.
So this is clearly not an issue all of these bikes share.
V1 really pushes his anti WD agenda at every opportunity. I have no idea why he hates WD but it is obvious to all of us that he does.
Blipping is a known issue with Vics in general. It is a bad practice that can lead to stalling issues. I never have a bit of trouble from my engine but I have never been one to blip my throttle either. Only HD riders who have drank the kool-aid blip the throttle for no reason at all, at least in my opinion.
If you are having issues with a new bike, by all means bring it to your dealer and make them fix it. We get a full year unlimited warranty for a reason, stuff happens.
Discussion Starter · #18 ·
Im no Harley guy, Im not trying to make a bunch of noise, Im trying to ride my bike the way I want and down shift the way I know how.
Why you would say its a bad habit is beyond me. Again, with a racing back ground, thats the only way you do it, any I dont think to many racers out there would argue with that. I know im not racing on the street, but Id like to ride my bike with a little fun and just poke around on it.
Hell Ferraris only come with paddle shifters these days, but even still, when you pull the down shift paddle, its blips the throttle by itself, ups the revs, and down shifts. ( I do understand thats a car and a totally other subject) but there is a reason for why you do it and I would certainly say its not a bad habit.
Fastfords, I agree with you. There is no good reason that your new bike is popping and stalling and unless you don't know how to ride, which clearly appears to not be the case, the bike has something wrong with it. I have a 06 Hammer and have put about 3,000 miles on it this summer, and downshift as you describe simply to not lose traction or put extreme pressure on the transmission and it never never has popped nor shut off. It is a cold bike so I do have to give it a few seconds to warm up before riding but I think you have a problem with the dealer. I have found that they do not often know what they are doing until you find one with good mechanics. I am thrilled with my bike and am very sorry to hear the problems you are having. i think you need to remain steadfast the the problem is not you but that there is either fuel injection issue or perhaps an electrical issue yet to be properly diagnosed and repaired. Keep looking for a competent dealer as they do exists.
1 - 20 of 193 Posts
