Sorry, didnt see it posted and with the app i dont see signatures, thanks.
Sent from Motorcycle.com App
Shane look what I found on another forumHey guys,
I am the owner of a new 2013 8 Ball, I bought it brand new last month from Hernleys in Elizabethtown PA. Ive been riding since I was 12, ( Ill be 24 soon). Raced motorcross, track days all over the east coast on sportbikes, you name it Ive probably been there, so I consider myself an experienced rider, as well as a Mechanic as that is my profession.
Id just like to get that out there so nobody thinks im new to this.
Anyway,
Within the first 50 miles of a brandnew bike, it shut off on me 4 or 5 times. All of them happen as soon as I pulled in the clutch to downshift. Just shut right off. I took the bike back to the dealer, waited around an hour and was told they found a loose nut on one of the circuits and hopefully it was fixed.
Around a week after that, it has shut off on me several more times, not even 150 miles on the bike yet. Again, each time it happened it was as soon as I pulled the clutch in to down shift. Back to Hernleys.
I took the bike back monday sept 30th. It took over 9 days to get my bike back, as I picked it up October 9th. They told me twice they didnt get a chance to get around to looking at it, and then we had to wait for a part.
I was told they replace the Idle Air Control valve and that, Duane, the owner wanted to talk to me. So we talked, and what he told me was this.
That they went ahead and replaced that part, but it was likely my fault the bike was stalling because;
I AM NOT SUPPOSED TO REV THE BIKE, AT ALL, AS IT CONFUSES THE FUEL INJECTION. DONT REV IT WHEN YOUR SITTING STILL, AND DONT REV IT TO DOWN SHIFT, JUST PULL IN THE CLUTCH AND SHIFT.
Seriously?! I cant rev my bike to down shift??? He said it as if it was a normal thing and no big deal.
Anyway I took the bike home, 15 miles later it has shut off twice, and it is now back firing a good bit, random pops, poor bottom end, as well as throttle responce.
Oddly yesterday while riding I ran into another Vic owner. Bought his bike from the same place, was having similar issues, and got the same story, DONT REV THE BIKE. I thought this was weird.
So today I called two other semi local dealers.
The first I called was not suprised to hear from me, in fact he seemed to know my story before I told it, and said they fixed 8 or 9 bikes, all that were bought from Hernleys within the past few months due to bad service and a rude owner.
He was familiar with my issue and told me that they had seen several fuel injector issues, poor seating of the injector, or bad orings on them, so this may be part of my issue, but he said there is no reason at all why I should not be able to rev the engine for down shifts, as we all know thats what you do with any manual gear box.
Also while my bike was at Hernleys the 2nd time it got a nice scratch on the side cover, probably from someones boot as they went to get off the bike. The owner "buffed it out", well guess what, the scratch is still there and he could care less.
So thats my story.
A brand new bike that runs like crap, serveral people from the same dealer with similiar problems and no help from the origial dealer, and im being told, NOT TO REV THE ENGINE, like its a normal thing for these bikes.
Sorry for the long read, but has anyone had these issues or is aware of a fuel injection issue, electronics problem etc etc? This is a real low blow for me as I have a brand new bike that seems to be getting worse and worse with each mile.
Thanks,
Shane
Hey guys,
Anyway,
So thats my story.
Thanks,
Shane
First, I havent taken it to that dealer yet because Im unsure of them. I got two private messages from two users on this board regarding that dealership that had used them in the past. Both had negative things to say and seemed like they left with more problems then when they showed up.I see the same people are still giving 1001 pieces of advice and not a single one of them has a clue.
You have another dealer whom you talked to who has told you he can fix your bike yet you still have not given this other dealer a chance to correct the problem/s you are complaining about.
You need to stop pissing, bitching and moaning and take the bike to the other dealer and let them look at it and see if they can fix it.
I take it your ride with the dealer you have went to you were unable to duplicate the conditions you are complaining about on that ride you said you and the dealer were going to do.
I know you don't like to hear anything except from those who agree with you, but has anyone tested the emergency engine cut off switch to make sure it is not the problem? I guess that makes 1002 pieces of advice now.
Or even test the damn thing.Thats the service im getting. I spend 13 grand and you wont replace a 5 dollar switch thats under warranty.
Maybe not a function, but what if it's shorting to something causing a voltage glitch that kills/resets the ECU?The clutch switch has no function that would shut the bike off.
Lets get this correct. You are still piss, bitching and moaning and are not allowing the dealer to even have a shot at fixing it.First, I havent taken it to that dealer yet because Im unsure of them. I got two private messages from two users on this board regarding that dealership that had used them in the past. Both had negative things to say and seemed like they left with more problems then when they showed up.
So perhaps they arent as solid as they sound.
Second, yet again your assuming that I went on a ride with the dealer.
"I take it your ride with the dealer you have went to you were unable to duplicate the conditions you are complaining about on that ride you said you and the dealer were going to do".
Wrong Again! Like I said quit assuming because youve been wrong every time.
I work 12 hours a day all week long, havent had a single day off in months now. As I explained to the dealer, I simply dont have time to go on a ride with him, even if I did, its a waste of time. They can ride it themselves and find the problem, only issue there is they only ride it a mile up the road and back.
Then it isn't the switch, it's a short.Maybe not a function, but what if it's shorting to something causing a voltage glitch that kills/resets the ECU?
LOL, it is young guys like you and the original poster who refuses to take his bike to a Victory dealer but complains about it in these forums that give you young entitlement generation a bad name.Vic 1 this ain't even my thread and your pissing me off. It's crotchety old pricks like you that give nice old guys a bad name. Do the world a favour and stop speaking.
Lol. It's people like you that buy products with out researching them first. Then pay to much and come on forums, like this one, and complain about it.LOL, it is young guys like you and the original poster who refuses to take his bike to a Victory dealer but complains about it in these forums that give you young entitlement generation a bad name.
Lol your killin me man, where you you come up with this stuff?!Lets get this correct. You are still piss, bitching and moaning and are not allowing the dealer to even have a shot at fixing it.
Now you are against two Victory dealers who you have openly admitted have tried to assist you.
Sell the Victory and buy your damn sport bike or better yet go join the flock of sheep at Harley.
Also why do you say im refusing, if you read my original post, it clearly states the bike was taken back within its first 50 miles, then taken back the second time and it spent 10 days at the dealer before it even had 150 miles on the clock.LOL, it is young guys like you and the original poster who refuses to take his bike to a Victory dealer but complains about it in these forums that give you young entitlement generation a bad name.
