New headlight turn signal
228 Views 2 Replies 3 Participants Last post by  53canuck
Good morning everyone!
I have a 2015 gunner that I decided to switch out the headlight and turn signals. The headlight has turn signals integrated into the headlight. Both are LED. I want to just hook everything up and be done with it. But when I connect everything, onle one side fully works and the other side doesn't do anything. What would I need to add or replace
MONDEVIEW 5-3/4 5.75 Inch Motorcycle Headlight Led Round 5 Light Modes Headlight 100W 20000LM 6000K+4300K Angel Eye 9-30V https://a.co/d/hvRaW6n
1 - 3 of 3 Posts
silly question, but have you checked that the turn signal side that isn't working is wired correctly? if memory serves, there were some bikes that had the polarity for one of the turn signals reversed from what was in the manual. you prolly could find more info about it by searching the forum, but i do remember there were some posts about turn signal wires not being correct in the past. if you have a meter, it might not be a bad idea to stick it on the wires and make sure you have power. also, i don't know if the gunner came with LED turn signals, but you might need a load resistor to eliminate hyperflash....
this is just my $0.02 and not worth much, but after watching their video (kinda useless) on amazon and some of the customer videos, those led turn signals in the headlight are gonna be tough to see..... maybe at night it will be more visible but looking at some of the day time shots, i dunno... think you might be opening yourself up to one of those "i didn't see him" kind of excuses...
just an observation....
See less See more
Reactions: 1
Agree with MM. On my bike the polarity on one side was reversed from the prints and you have to assume what they meant to do. Simple bulbs will work in either direction so there's no indication ahead of time that something is wrong. Don't just flip it, get a cheap multimeter and make sure ahead of time.
Reactions: 1
1 - 3 of 3 Posts
