1 - 14 of 14 Posts
Finally ditched that abhorrent stock bulb for some LED goodness. This baby burns whiter than my honky azz in the middle of winter. (take my word for it)
While it can't be seen unless you look at it from above @ close range- I have an LED replacement coming for that fecking mini- mag-light bulb at the bottom too..
Be advised that a little bit of grinding & trimming is needed to acquire a perfect fit. The yellow-ish bulb support needed to be enlarged slightly, and the very smallest part of the center of the black bucket support needs to be cut out to make room for the heatsink/ fan housing. The ballast on this thing is tiny- no issues there.
So everything is still stock (housing I mean) only you changed the bulb and ballast ? Why would there be any grinding involved ? the 3 lips of the new bulb does not correspond with the stock housing (3 lip holes) ?
I have this questions coz I just burned my HID ballast on my high-beam and sadly had put my stock bulb in there again ....
I just replaced my stock bulb with a LED. The black bracket behind the light had to be enlarged to fit the back of the bulb (looks like a heat sink or fan). Not sure what this bracket actually does. I think it may hold the wires in the headlight bucket from touching the back of the light reflector due to heat. Wouldn't mine confirming this.
@BP6666VR.. HID ballast burned out? What caused that? Theres warranty on the Victory HID isnt there?
Discussion Starter #5 (Edited)
Yes all stock other than the bulb/ ballast. I believe the yellow ring is the support bracket for the bulb itself- what it 1/4 turns into. The bulb assembly has to be separated (it's made that way) Then put back together through the hole. It's just slightly too big- so a very minor adjustment to the opening is needed. There's a couple small parts and tiny screws involved.
The large black support bracket (removal not mandatory) looks like a series of concentric rings- like a round basket. It supports the reflector & bulb assembly. The LED has a fan / heatsink assembly that simply will not fit through the center hole. That got snipped and the leftover nubs got ground down. (just the very center needs to come out- zoom in on #5)
The back side of the bracket is a tangled mess of wires of all sorts. This is probably why there is absolutely zero spare wire length for that useless lower mini bulb. Can barely plug it in. It's probably tangled up in that. I have an LED coming for that too- just for that uniform appearance and it may help shape the beam a little as well.
I had a independent Victory guy local to me do this. He has installed several of these- including onto his own bike- so he has that familiarity with what needs to happen.
I just put a better bulb in mine for $15, good investment.
I dicked around with the Victory HID kit beforehand, probably wasted a day on it, but it was poor quality, did not fit, and not at all suitable for the Judge
Didn't know that ?? Yes high beam ballast isn't working for 6 months now .... Low beam is all good mate, don't know what caused it ... Regularly use high beam here, but expected the bulbs to fail before the ballasts ... Maybe I should ask if I can try to repair it locally ... It has bolts on it ?
Tiger + Judge Redd + AfterDarker
Great info, but AfterDarker I just LOVE the HID bought from this site member ... They are super quality and very bright ....
Yeah- I have no doubt it's a good kit, but I just didn't see it fitting in the round headlight assembly- which is packed almost full from the line. Plenty of positive recommendations from those with the bullet housing- not so much for the round ones.
I was contemplating one of those "Speaker" brand complete LED assemblies, but that was in the mid $200 range. I'm pretty thrilled with the bulb I got. Both the main bulb, and the little T10 one (inbound) will total up to less than $75 including all shipping.
The difference is mate you have a Jackpot with a different headlight to the Judge and while the Jackpot HID kit might be good, the HID kit produced for the Judge was just rubbish. Worst bit of kit I have ever bought for a motorcycle and completely unfit - literally - for purpose. But at least the vendor provided a quick refund.
@BP6666VR. You bought the Vic.HID kit off CrossRoads, I'd suggest you give him an email thru his site
CR is the man to be talking to.
No bolts on the ballasts I'm using
Yeah mate crossroads .... Super cool guy ... i'll write him a email
See the back of the failed ballast with the screws ..
Ahh yeah, screws not bolts.
Tell ya the truth I cant really remember what my ballasts looked like except they didnt have bolts.
Thought mine were slimmer but its been a while and my memory fails me.
Yeah hope you can get it sorted and hopefully work out why...
1 - 14 of 14 Posts
