1 - 5 of 5 Posts
I am new to the to Victory Forum Site.
I am hoping you can help me with a question.
I have a 2016 Cross Country Tour that is leaking oil.
I have checked the engine oil level and it is still good.
It is leaking from behind the engine so I believe it is coming from the transmission.
None of the books or websites tell me how to check the transmission fluid level.
I have looked and have not seen any place on the bike to do the checking.
I have an appointment with the dealer to bring it in, but I would like to make sure there is enough oil.
Would not like to damage any thing.
Hoping someone can tell me where it is located.
Thank you
Roxann :confused:
Unlike Harleys, Victory engines share the same fluid in all three cavities.
Bihind the engine is the carter breather or sump breather, a hose is connected there, if it comes loose then a oil-mist will spray over your bike, but the oil level will still be good ....
Andre using TaPaTaLk
That is good to know. At least I know I am not crazy.
So as long as I have oil in my bike, I should not have a problem getting it to the dealer.
Thank you for you quick reply
Roxann
Roxann
Can you check if the breather hose is still connected ?
Better clean all the oil off, then run the bike and see where it comes from ....
Maybe a loose bolt on your primary ?
All easy solutions
1 - 5 of 5 Posts
