1 - 5 of 5 Posts
Greetings again!
My first bike is a 2002 V92C. I love it! But I'm new to bikes, and it's used. 15000-ish miles on it when I got it. I've had it just over a month and put over 1000 miles on it.
I have an issue...I can only call it a "surge". It "surges" and kind of feels like it almost wants to cut out on me until it gets warmed up. At first, I thought the "fast idle" might be fouling the plugs. I replaced the plugs. I've made sure to use non-ethanol gas. It still seems to be an issue. Primarily when I first get it going. After a couple miles it quits.
Any ideas?
Thanks!!
I do. In the mornings before work....up to ten minutes. After work...2-5 mins. It's probably a warm up issue, but like I said, I'm new...so not knowing what to expect, it's a bit disconcerting.
Have you checked their filter? Also, the throttle bodies on the older bikes get dirty and the bike will start to run rough and foul plugs. Clean those and see if that helps.
1 - 5 of 5 Posts
