1 - 12 of 12 Posts
My 2005 Kingpin has a bent frame but I have access to a 2006 frame. Does anyone know the difference in the specs? Could I modify the 2006 to work without too much difficulty?
Oh yea , Welcome aboard !cheers
I'm hoping so. They're different part numbers from the dealer and they changed to a 6 speed tranny and a larger motor in 2006.
I may have jumped the gun on my answer , the exhaust mounts seem to be similar , but different . That seems to be the only visual difference . You more then likely can work around it , you can do anything if you put your mind to it , and have the right tools .thumb up
I was afraid of that. Is the frame itself narrower or is there a mounting bracket that's different?
Frame is narrower at the bottom of the legs, and offset of the mounts is changed a little
1 - 12 of 12 Posts
