1 - 3 of 3 Posts
Hi all,
My rear cylinder isn't firing. I have spark and 160psi on the cylinder. I replaced the spark plugs and the rear one keeps getting black and isn't wet. The injectors look clean and I swapped the front and the rear ones and the issue didn't change. I even pulled off the Dynojet Power Commander. I can't figure out why I am not getting fuel to the cylinder. What should my next step be?
The computer controls fuel to the injectors I think so maybe there's a problem there or in the signal to that injector. Then there's the TPS and TPS reset to check or try. Howabout the plug wires. Are you able to swap them or try any plug wire that will fit for testing purposes.
Change your battery
Unplug your injectors,
Pug them back in
Start your bike ....
I had this code before ....
Andre using TaPaTaLk
1 - 3 of 3 Posts
