1 - 8 of 8 Posts
A customer sent me this after we installed a PCV, Lloyds Air filter and our Thunder Monster Exhaust Mod. So figured I would share.
Discussion Starter #2
It is on a 2011 Cross Country.
That's about as perfect a dyno chart as I've seen.
I thought the cross between HP and Torque was supposed to be somewhere close to 5200 rpms???
Yup, they do cross at 5250, when using the same scales. Not sure why anyone would want different scales on a dyno graph..... maybe you can ask your customer to sync his scaling setting in the Winpep software and send it to you again?
Not sure if using diff scales or not. But seems like all the gains are at low to mid ranges. Which is your mostly used area is it not?
1 - 8 of 8 Posts
