1 - 9 of 9 Posts
New to the forum and would love some help, I have an 06 Hammer that due to certain life consequences I let sit too long. I have drained the tank, added new gas, can hear the fuel pump when cycling kill switch, pulled plugs to confirm spark, they also are wet so I know I am getting fuel and spark but still wont start. Any help would be greatly appreciated. Thanks
Not an area I have a lot of knowledge in, but....
Welcome from Alabama!
The plugs may be fouled now. Put new ones in and see if that doesn't fix it. Need three things, fuel, air and ignition source.thumb up
Thanks, yeah good spark and fuel, found an awesome tutorial on YouTube from a Rylan, trying it when I get off work, will let you know how it goes
Let us know how it works out for you
wet spark plugs will not fire. You need new ones buy a couple sets.
Just cause you hear fuel pump doesn't mean its any good. Go to auto store rent fuel pressure tester. You want 49psi or higher.
https://www.youtube.com/watch?v=CCOJWC2Xrs8
Yeah thanks, getting a pressure gauge after work. Watched tutorial done by a guy who rebuilds fuel pumps told me it needs to be 51 or higher,. But thanks.
1 - 9 of 9 Posts
