1 - 4 of 4 Posts
Got the Octane a few months back and i want to replace the handlebars on the Octane w/ cable kits. I've been looking to get taller handlebars probably 10" or 12" but I cant seem to find specific cable kits besides Burlys (harley kits) any tips would be helpful on any part of the assembly i want upgrade majority of parts on stock bars.
Nobody makes a single kit you can buy that i am aware of. I am pretty sure
Check dean speed for bars. http://dean-speed.com/your cables will still reach with a 10 inch but it will be tight.
Magnum cables makes clutch and brake lines Magnum Shielding
The sock bars are 8inch and the reduce reach bars victory sells are a 10 inch. You can go up to a 12 inch without extending your wiring but if you need to here is a kit NHCX-IS18 - Fits: (2015-2020 Indian Scout & Bobber Models ONLY) - NAMZ Custom Cycle Products
The NHCX-IS18 will work with the octane. I emailed them and they said it would not work, i told them i believe they are incorrect and i sent them pictures and they said they are indeed the same connectors. I ended up just extending my wire my self with out that harness.
1 - 4 of 4 Posts
