1 - 18 of 18 Posts
Is anyone aware of a part number for the OEM cheese wedge badge (106)? The Polaris parts listing shows the plastic cheese wedge but not the badge.
I removed my ignition ket and want to cover the hole. I know I can get an after-market badge (and I like some of them out there), but I would prefer to have it match the stock right side.
it is this 7174703 you'll love this $40.99
look on ebay
Holy crap! For that price, they can keep it!
I'd be better off getting a pair of custom ones for a bit more.
Thanks!
Thanks!
Barracuda Customs runs about $45....but that's each so if you want them to match your not looking at a little more....your looking at double.
You put the guard dawg system in correct? Any pics of how/where that mounts? What does it do? Ive never checked into it.
Sent from Motorcycle.com App
Discussion Starter #11 (Edited)
I didn't take pix, but it was simple I mounted the actual unit to the back of the radio. It's about the size of jewelry box. The ignition switch comes completely out, and the plug connects to the unit
All told, it took me a couple hours including fairing removal.
Basically it allows me to keep my keys in my pocket. The bike will only energize if the key fob is in range (about 10 feet or so). The actual on/off is controlled by the run/stop switch.
Would you care to rethink that statement?:ltr:
first thread ive read in a while and there you are. havent been
keeping up. 10 degrees sat night. barracuda has very nice
badges. i bought the left one to match the right.
Does the fuel pump run and/or the headlights turn on when you get within 10' or so or is that all controlled when you turn on the kill switch now too?
So its like the newer dodge cars? My wifes car doesnt use a key, just need the fob near it, good thing with it is you cant lock the keys in the car!
Would a right side cheese wedge mount on the left? Then you would eliminate the hole altogether.
Discussion Starter #15
It's all controlled by the kill switch. You can think of it as not allowing the kill switch to turn the bike on unless you are within 10' of it.
Believe it or not, the right-side cheese wedge has the keyhole in it too; it's just covered by the badge. Left and right are even the same part number per Polaris' parts book (for the XC/T, anyway).
That is CHEESY!
Discussion Starter #17
1 - 18 of 18 Posts
