1 - 2 of 2 Posts
Okay for a little background, I just installed new pipes on my 2012 Kingpin and in the process (after a few hours of frustration) I removed the oil cooler to give myself room to swing the header around the bike which worked like a charm to get the pipes on. However after reassembling I apparently didn't get the oil lines seated all the way into the oil cooler which lead to the oil cooler puking oil onto my floor, I got the engine stopped immediately so no harm, no foul. I gingerly used some slip joint pliers to seat the oil lines onto the o-rings and it worked, I took the bike for a ride around town to test out the pipes and constantly watched for leaks and it was fine. Once done with my test ride I parked the bike and because of this wonderful Ohio weather it's been parked for a few weeks now. I started it up last night to let my buddy hear the new pipes and it started leaking from the oil cooler lines again, this was a pretty good leak too.
Now I'm assuming that I extruded, twisted, crushed or otherwise damaged the o-ring in some manner. Does anybody know what size o-ring I need as a replacement, so I can avoid a trip to the dealer? Also, I don't see any good way to really get ahold of the oil line to seat it into the oil cooler, any suggestions?
Looks like you will need part 10 and 11 on this diagram: Link cheers
1 - 2 of 2 Posts
