1 - 9 of 9 Posts
Is there any reason that the existing oil cooler on an '01 v92c couldn't be moved to where it is on the newer models, or replaced with the new style all together?
will anyone or does anyone make a higher capacity cooler
for victorys such as my xr or is the vic one more than adequate?
ive heard that there are fan driven ones for h d.
Why? Your bike will never overheat, so why would you want a bigger oil cooler? You can ride it at parade pace in the middle of the desert and it won't overheat. HD's on the other hand... well, we won't go there. :ltr:
While CrossRoads makes a bold statement about "never" overheating, Victory did downsize the amount of oil and reduce the size of the oil cooler to make the bikes warm up faster. I would think without thermostats or fans the oil cycles through a big range of temps from maximum cooling to idling for long periods, but these seem to fall in an acceptable range. It would be interesting to see the oil temp immediately after a stop and watch how fast and how high it will get.
Thinking about changing mine to the smaller one. This thing on the front of the 99's are huge.
cooler oil temps= longer engine life.--
maybe we dont want to know what the oil temp is!
1 - 9 of 9 Posts
