To re-awaken this thread I have a question regarding my 2012 CCT. Since I bought the bike a little over a year ago it's had an oil seepage leak coming from between the fins where the head meets the cylinder. From reading different threads it appears like it could be the porous head issue and I haven’t had any luck getting a dealer around here to provide any advice on it (granted I haven’t been pushing the issue either since it’s more of an annoyance than a problem). However, when I began to leave for work this morning I had a more distressing oil leak, immediately behind the kickstand I had a puddle of oil about 8” around and since I was leaving for work I didn’t have a chance to investigate further. Needless to say, the best riding weather we’ve had in over a month and I’m cage bound
Anyway, it doesn’t say what this particular oil leak turned out to be, can anyone say whether or not it was just loosened primary bolts or a primary gasket which failed? Is it common (relatively) for primary gaskets to just suddenly fail or for bolts to suddenly loosen? The amount of oil which leaked gives me concern as it wasn’t a “dime” spot or seepage but a full blown oil puddle. Any suggestions are greatly appreciated, thank you in advance.
