1 - 2 of 2 Posts
Hi, I ordered this unit, however it only came with the wire harness and the speedometer, but no chrome housing cover or mount bracket. Is this normal? I have a dual speedometer and tachometer that came with the bike, but wanted to change over to the newer unit. I order part 2875926 as I have seen in these forums. Searches on the internet show 2875926 in the chrome housing cover. Is this just another misleading purchase where I have to buy more parts?
Yep, that's how it ships. It's meant to replace the single speedometer setup, what I had on my '06 8-Ball. You'd need the speedometer bracket mount (part number 5247852) to replace the speedo/tach mount you currently have (part number 5247622). You might be able to use the housing cover you already have for the stock speedo but just in case the part number for this is 5246297. If you want to double-check this follow this link: http://parts.polarisind.com/Browse/Browse.asp
1 - 2 of 2 Posts
