1 - 14 of 14 Posts
Hi, I am looking to change the indicators on my Highball as the stock ones are HUGE! I am thinking of something like these LED's with clear or smoked lenses.
http://2wheeljunkie.co.uk/motorcycle-essentials/oxford-indicators/oxford-diamond-ledicators/prod_8565.html
I can see on the rear of the bike you can unscrew the old ones on the number plate holder. That should be easy right? Is there a better tail tidy that I can use? I don't want to go sidemount.
What would I do on the front? The stock ones have the ring fastner that goes around the top of the fork but it is part of the stock indicator. What can I buy to make this style of indicator mound to the front of my bike?
Thanks!
Are these my only option? I like them but $85 is a fair bit but once I get them to the UK they will cost a fortune just for mounts!
You can get term both in black. I'm just going to have to cough up for the Viconly ones aren't i? Are the really worth 2.5x as much?
How do they actually mount to the indicators? I can see how the mounts attach to the forks. Do the indicator stems screw into the holes on the mounts? Are they threaded? It's a bit unclear from the photos.
Also VicOnly has crome mounts when you click into the bullet indicators that are only $38.95 for the Vegas. Are they the same? If so why are the black ones double?
Just to confirm, Vegas/Highball forks are 43mm and Harley ones are 41mm. Is that correct? I might be able to get HD ones cheaper that are already in the UK.
Discussion Starter #13
1 - 14 of 14 Posts
