1 - 3 of 3 Posts
Thinking about removing my O 2 sensors on my 2012 XCT and buying the plugs from Witchdoctor. My question is where do I find them to do this and does it make a difference with the scoot running cooler. Thankd
You will run cooler and a tad bit richer (or I should say you will be running less lean).
Simply disconnect the O² sensors (here's how: http://www.victoryforums.com/showpost.php?p=24760&postcount=1 ). If you decide you're ready to permanently remove them, you can do so at a later time and get the plugs.
Thanks for the help
1 - 3 of 3 Posts
