^^^^^+1^^^^^^Just a guess, but you would thiink a flat black used on bbq pits would work, it would take the heat.
I believe gary has the answer , i also used the bbq black on exhaust, rust-o-lieum bbq black high heat resist heat up to 1200° [ according to the mfg. ] ive not had any prob, clean with acetone, apply to cool pipe, the color also seems to be the same as used on the engine, i sprayed my cam covers hides the otherwise stand out appearance,Just a guess, but you would thiink a flat black used on bbq pits would work, it would take the heat.
