1 - 6 of 6 Posts
Can undamaged, new clear-coat be painted over or does it have to be "prepped" somehow?
I would think scuff and go just like any other clear. Vic's clear is solvent based. I'm NOT a painter though.
wet sand with 180 or 2000 grit with "wet sandpaper" is not the same as normal sandpaper. Now put down a coating of primer then paint.
Look on youtube how to
i hope you meant 1800 grit , not 180. 1000 grit would be ok,
just make sure its thoroughly deglossed . even a grey 3M
scuff pad would work. 2 coats of clear should be plenty.
i use ppg products at my place.
1 - 6 of 6 Posts
