1 - 7 of 7 Posts
I suspect you may need to be more specific. Are you talking about electrical connectors? If so, are you talking about the small one that is external to the bars and connects the clutch switch to the harness (if the 8-ball has this)? Or do you mean the male/female connectors for the main wiring on that side? I don't know the 8-ball but on the XCT, these are in the fairing. In my wife's VTX1300 and my HD softail (neither of which have a fairing), these are located in the headlight bucket and under the tank, respectively. I'm sure someone can help if they know exactly what you are in search of. Good luck.
G'day,
Vinish
@ Vinish: thank you for your response.
Yes, the electric connector to the clutch switch and the main connector which goes inside the headlight.
I purchased the bike without the left hand control. I found a left hand control from a 2008 Vegas 8 Ball but the connectors do not match with my 2007 8 Ball
Thank you!
I found the control of the left hand side but unfortunately the connectors are not separate listed.
Any idea if it is possible to get those separate?
go to auto parts store and see what they have. Might need to go to more then one store. Heck look on ebay for connectors
1 - 7 of 7 Posts
