1 - 3 of 3 Posts
Does anyone know what C ring you need as a replacement for the wire spring that hold on the pivot pin for the passenger pegs. I watched the witch doctors vid and used a screwdriver as a chisel to cut them off. Now what do I use to replace them? Victory says they discontinued the old C rings they used to come with. If I go to the hardware store to get one, who has had luck and what size did you use?
5/16" snap ring
Thanks Drew
1 - 3 of 3 Posts
