1 - 4 of 4 Posts
after you install these how do you activate auto tune? Window that is showed in the instructions don't even exists inn the CD software that is included with PCV...off any one could point me in wright direction about doing this I would greatly appreciate it
2012 XC with PCV/autotune
If I remember correctly. It didn't look exactly like the manual. I won't be able to look until latter in the day.
One other issue is the O2 sensors may not be recognized. A firmware update may resolve that.
You also might need to update the software for pcv.There are help files under the support drop down on the pcv site.On your software open the tools menu.Then open configure.Should open a window with a box to check to turn on and configure the auto-tune.Hope this helps.
Thx guys I'll look again after work out just does not seem that bike got that extra power
1 - 4 of 4 Posts
