1 - 20 of 55 Posts
I put new pipe on my crossroads it already had a hi flow filter ( not Lloyd's ) disconnected the O2 sensors but she is running very lean. Plug is white when pulled. Do I need to flash the ecu if I put a PCV on.
Flash or PCV either one will work for you. Or you can just put the regular filter back in and plug you 02's back up. I have been running mine with just gutted pipes for over a year with no problems.
No, you don't need to flash the ECU if you put a PCV on.
Yes, what Rylan said. thumb up
Plugging the O² sensors back in will allow the bike to run as lean as the Government intended it to run. I would leave the O² sensors disconnected, unless you're trying to set new EPA records. cheers
I think I'm going to do the PCV as later I will be adding a Lloyd's filter.
Thanks for the info
How many miles on the plugs?
What is your gas mileage? Between 40 and 44 is not lean more like average.
Just put new plugs in did 30 miles found out previous owner disconnected the 02s sensors. Pulled plugs were black. Put the new pipe on left 02's off did 2 miles checked they were white.
30 miles isnt long enough on new plugs especially if you put ngks back in, they take forever to color, if the old ones were black your rich.
No way! :crzy: What color where the plugs, when brand new? White? Oh, yeah, it would take more than 2 miles for them to change color.
So I'm just being paranoid. I will put a picture of plug up later see what you think the old ones were showing rich for sure
yes. if it was that lean the old plugs would be white still and you would have had driveability issues.
The first sign of lean , is surging ... You bike wont be able to hold a steady speed under the slightest load and you will feel an uneven speed constant .... As the motor is thirsting for more fuel ...
KPR, you are in south NH. close to R.I. KMC is there. Get a PC5. save your money on the flash and get a timing wheel. Then take your bike to KMC and let him tune it. Unless you do a set of cams, your done. you will have a tuned bike. No more guessing. Spend wisely my friend!
Two different style plugs and I bet heat range to.
How did you pick out that Iridium does look like the right one.
What is the first plug champion plug?
You never say what your getting for gas mileage
Discussion Starter #18
the iridium was in there. I asked dealer for ngk stock plug that is left plug first 30 miles stock pipes no o2 sensors then did bassani 2 into 1 down the road and back about 2 miles plus a few min warming her up. It didn't feel like it was surging or anything out of the ordinary.
A proper plug chop involves starting with 2 new plugs.
accelerating the bike through the gears into a fairly high gear,
a dragstrip or closed section of road is ideal.
A dyno also though youre not pushing against the air to fully load the engine.
As you cross the finish line or when its pulling hard in fourth gear pull the clutch in and kill the motor at the same time, don't allow the bike to slow under its own power. and don't let it idle before your run.
Reading a plug is a science in itself, there are many websites concerned with such.
http://www.wallaceracing.com/plug-reading-lm.html
Mags is right about the surging too extreme leaness will show up there as well as on the plugs
1 - 20 of 55 Posts
